Button Save enabled only if all questions are answered
Hello all,
Hi all
I would like the save button to be enabled only when the user has answered all the questions ( Questions step 1 and Questions step 2).
Can you show me how to do it please?
Thanks you in advance
(1,504 Views)
Use Property Node of Save Button and use options (Enabled/Disabled/Disabled and Greyed Out) based on your need.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,497 Views)
Hello PalanivelThiruvenkadam?
Thanks for your answer
Yes I know the property node Enabled/desabemd and grayout but my concern is how to tell it if your questions are answered
Can be value with a condition structure?
(1,488 Views)
Initialize with Disabled with Grayed Out and Once you know the feedback from user that last question is answered you can enable.
(1,484 Views)
Accepted by topic author Steph_2
Please  check the attached files for reference.
(1,481 Views)
(1,455 Views)
