Button cancel, next
@Ngouda wrote:
Hello Altenbach,
Yes, you are exactly right.
Now I'll explain what I want to do:
You see the 5 items I put in Question.vi?
For each item that appears the user has to choose a value on a scale from 0 to 20 (I made a radio button of buttons from 0 to 20) and I save it when he presses the save button.
After the second step I make combinations of these 5 items and basically I would have 15 combinations. And for each couple (for example the couple Requirement, performance) the user must be able to write 1 in the corresponding box like a form in fact.
So I reuse the same controls.
I know how to make a form and fill the boxes.
But how to make the combination of these items so that I don't create several of them and that my code is optimized?
And thank you for this exchange it helps me a lot, I am new on Labview.
Sorry, it is still not clear. You always use very ambiguous terms (items, boxes, forms).
So you have five questions and the answer to each is a number in the range 0..20 (21 possibilities). I guess you end up with five integers in that range, one for each question.
You lost me with "combinations of items". Are the 5 items the five questions? How does that result in 15 combinations (and what does that even mean?) Is the user entering 1 into an empty box? String control? Numeric control? The same control as the question display? Should the question text remain or replace by "1"? What else is he allowed to enter? What should be done with the entry?
I am pretty sure we simply have a language issue. Since the program seems to be in French, maybe you could write your description in French and use google translate?
Message 11 of 14
(1,259 Views)
Accepted by topic author Ngouda
Here's a quick draft for the first steps.
Message 12 of 14
(1,250 Views)
Hello @altenbach,
Thanks for your answer, it will give me a good start and with these elements and the documentation I made all weekend I could continue.
Sorry if I'm explaining it wrong. When I said combination I meant:
couple:
1 Performance requirement
             requirement: ((user filled 1ou 0)
             Performance: ((user filled 1ou 0)
2 Performance Frustration
             Performance: (utilisateur rempli 1ou 0)
            Frustration: ((user filled 1or 0)
3  Effort Requirement
            Effort:  ((user filled 1or 0)
           Requierement: ((user filled 1or 0)
4
And so on
15 Effort Frustration
And the user will be able to choose one of the two (either Requirement or Performance and fill in 1).
The entries I will store in an excel file for example
But with all your answers I think I can manage now.
I will come back to this forum if I have other questions on this subject
Thanks a lot.
Message 13 of 14
(1,213 Views)
Hello dave TW,
Indeed you are right.
I looked at the examples you suggested and it's great.
And it helped me to understand a lot of things.
Thanks to all of you for your help.
Message 14 of 14
(1,205 Views)
