Button scaled with unknown criteria
Hello, I'm having troubles with some buttons that I created starting from the System OK button: as you can see from the attached screenshot two of those buttons are automatically scaled while the others are not (this button resize happens when I run the built version of my VI on another computer with Windows 7 without "Aero").
I cannot understand why this happens on those specific two buttons and not on the others.
I attach one button that resizes (Visible.ctl) and one that doesn't (Move.ctl)
Thank you in advance!
(3,500 Views)
anyone? i still didn't find a solution to this problem 😞
(3,422 Views)
Do the buttons have different settings regarding "Scale Object with Pane"?
Norbert
Expert: Geometry
(3,399 Views)
No they don't. And they are all packed in a cluster (even though I have the same behaviour on other buttons that are not in a cluster). The funny thing is that I used the button that does not change size as "template" and replaced in on the button that was automatically scaling, i put the same pictures that it had before and now I have all my buttons not scaling anymore. It's still a mystery that I would like to understand for my future developement (and I don't like mysteries)
(3,374 Views)
Hello cassaniti,
i tried it out and it seems to work both are scaled in the same way.
best regards
Alexander
(3,351 Views)
