Button to String
I am trying to create a button in which when the user presses it, it types in a string into a string control. How can I do that?
(3,137 Views)
Hi Aether,
So you want to do something like this:
IF button press THEN
  local of string control := "String"
ENDIF
So what have you tried and where are you stuck?
(3,131 Views)
Yes, this is exactly what I am trying to achieve in code terms. I still haven't tried anything yet as I am still confused where to begin.
(3,054 Views)
Hi Aether,
When you don't know where to begin this simple code then you should start with the Training resources offered at the top of the LabVIEW board!
After doing so you should start by placing a case structure in your empty block diagram as that is the LabVIEW way of IF-THEN-ELSE…
(3,045 Views)
No need to create a button, because it's already there. The code piece is in the PNG, you can drag and drop onto the block diagram space. I set the button to switch behavior.
(3,031 Views)
