Bypass ssl certificate error
Hi!
I am using .net for my webservices and are experiencing some trouble when moving to a new server. The code below works fine for my old server, but for my new server I get:
Error 1172 occurred at Error calling method System.Net.Security.SslStream.AuthenticateAsClient, (System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
I havent been able to correct the certificates and a work around would be to bypass the cert error.
Google tells me that something like this should do the trick:
ServicePointManager.ServerCertificateValidationCallback = delegate { return true; };
The question is: how can I do this in LabVIEW?
Message 1 of 1
(2,969 Views)
