Byte Arry to Number
Hi everyone!
I'm having some problems connecting an Arduino Leonardo via I2C to a myRio. I have a sensor connected (mandatory) to the arduino and I send data using I2C to the myRio. The problem is that I receive the data in Bytes and I want to know if it's possible to convert them into a number.
Thanks!
(3,339 Views)
Please provide more info on what data type you are receiving and with sample data.
uday
(3,316 Views)
Generally, "bytes" is probably a string. There are many number representations (integers, signed, unsigned, 8, 16, 32, etc. bits, SGL, DBL, complex and even arrays of those). As a first step you need to know what the target representation is. Do you have any documentation? How many bytes do you receive per number? Can the values be negative?
(3,307 Views)
