C++ DLL in LabVIEW
I have a DLL function call whose definition is
void * OpenComm(Char* device, char autodet, struct settings* setgs);
struct defn is:
struct settings
long baud;
char protocol;
how can i configure my Call Library function node for this?
i have used this before, but i have not interfaces with void* and structs!
(2,888 Views)
Hi rkpat,
There's probably another way, but I pass cluster-information as an array (see attached.)
Baud may need the byte-order switched - if your DLL wants it in Big-endian format.
The Device (char *) input can probably be re-defined as a C-string - then the explicit zero-termination won't be necessary (LabVIEW will take care of it).
As you know, CLF calls can be tricky, hopefully this is at least close to what you'll need. Smiley Wink
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(2,865 Views)
