C++ Exeption 0xE06D7363
I have installed LV18 plus the RT-, FPGA-Moduli, CompactRIO driver, LV Compile Farm and the Xilinx Compiler. As a Laptop I have a Thinkpad E490 (Intel Core i7-8565U Processor ( 1,80GHz 8MB ), 256GB SSD PCIe, 8.0GB PC4-19200 DDR4 SODIMM 2400MHz, Intel HD-Grafik 620). But I don't think the problem is my laptop as my coleagues have similar hardware.
Every time I want to open a code related to the FPGA, LV crashes and I get following error: C++ Exeption 0xE06D7363. Attached you can find the exact error window and a log of the error that occured. I already have reinstalled LV and the drivers, but nuthing has changed.
If i execute LV as admin, the same thing happens, LV crashes, but I don't get the error window. If I open a code with "normal" LV-Functions, then there is no problem.
We use the same software and drivers for years, and none of my coleagues had this problem before.
Can somebody help me with this problem?
Attached you can find the error log, a screenshot of the error window and of NI Max with the installed software.
Thanks in advance
TF_Zoe
Message 1 of 1
(3,260 Views)
