C:\WINDOWS\ServicePackFiles\i386\kernel32.dll
I am developing an app in LabVIEW 8.6 and sometimes I received the above msg when I launch my app.VI.
Thanks.
(3,473 Views)
What exactly does the message say?
Your subject line only gives a filename and path.
(3,468 Views)
This is the error msg I saw...
(3,450 Views)
Perhaps you have specified the full path to kernel32.dll in the CLFN which is not correct.  You should only put kernel32.dll in the library name and let the OS find it.
(3,446 Views)
I was using  "cmd /C abc.exe" to call another application.  Could that be an issue?
/Kawsy
(3,443 Views)
