C# .net dll usage inquiry
hello.
I'm sorry I don't speak English, so I'm using Google Translate.
I wanted to use Wyleg's Clinotronic S product as a labview, so I received SDK support.
I want to connect via Bluetooth using a dll composed of C#, but it doesn't work.
I used a .net struct node to extract the value, but it only came out as a reference and I'm stuck.. 😞
If anyone knows, please help.
(1,098 Views)
Accepted by topic author ndtsystem
I have a car and it doesn’t work! Can you help me?
Really you need to explain your problem in a lot more details. Not the language is your real problem but your believe in the supernatural abilities of the average user of these forums. I and surely almost every other user here on these forums can’t read your mind nor see the code you have on your computer but failed to attach to your post.
What .Net DLL are you trying to interface to? What is the C# prototype of the function you try to call and the datatypes it uses? What have you tried so far and why do you think NOT attaching that to your post will be helpful to others to be helpful to you?
Rolf Kalbermatter  My Blog
(1,076 Views)
