CAEN V2718 CONTROL WITH LABVIEW
We produce pulses with CAEN V2718, we use CAEN  vi-s and the first run is OK. We cannot change the pulse parameters in additional run .  Probably, The is a problem with CAEN  END function ?
(4,308 Views)
You are using a CAEN power supply? I don't see a National Instruments driver for that model "V2718"
Here is the list of CAEN drivers:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/ps/20/sn/ssnav:idr/q/CAEN/
What driver do you have for it?
Can you post your code? Or a snapshot of your Block Diagram at least?
(4,275 Views)
Dear Sir
We use power supply of Caen
The Vi is attached
Sencerely,
Zeev
(4,254 Views)
Please do not create duplicate posts:
http://forums.ni.com/t5/VXI-and-VME/Labview-control-of-CAEN-V2718/m-p/2801548
Please close this thread and follow the other.
(4,242 Views)
