CAN​インタフェース​デバイスについて
現在、CANインターフェイスデバイスの購入を検討しているのですが、LabVIEW2020でも使用可能でしょうか?
下記を見て使用できないのかなとおもっていたのですが、何かご存じの方いらっしゃいましたらご教授頂きたく。
(1,341 Views)
Maybe you type in english in an international forum, or do you expect we must speak your language?
Or post it on your language sub-forum
(1,310 Views)
@HY_ne:
Depends on what manufacturer you buy it from. If that manufacturer offers an either included or separately purchasable LabVIEW VI package, then you are good to go. Not all offer LabVIEW support.
The selection of the CAN interface also depends on the goals. Should it be just for testing, then practically any USB-to-CAN would do. Those built into the PC as PCI-E cards are not mobile.
(1,297 Views)
For new systems you should look into NI-XNET.
NI-XNET is NI's new CAN devices.
NI-CAN is the old product and is not supported in new version of LabVIEW.
(1,291 Views)
Sorry, I didn't know how to use this forum.
I'll be carefull from now on.
(1,273 Views)
Thank you for your reply.
I'm considering purchasing USB-8501 or USB-8502 made by NI.
Are these not supported in LabVIEW2020?
I would appreciate your cooperation.
(1,270 Views)
USB-850x is still supported in the latest NI-XNET 2023 Q1. This version of the driver supports LabVIEW 2020. NI-XNET 20.0 to 2023 Q1 support LabVIEW 2020.
https://tmesystems.net/
(1,258 Views)
