09-21-2022 05:40 AM - edited 09-21-2022 06:02 AM
Hi all.
I have a USB-8473 device from National Instruments and would like to read CAN messages that are transmitted by an ECU. I am following this link for the driver setup.
I managed to install the drivers: NI-Industrial Communications for CANopen, NI-XNET (which I might not need.), and NI-CAN.
Solved! Go to Solution.
09-21-2022 08:25 AM
Hi kulani,
@Kulani93 wrote:
- How would I go about writing a VI that reads the CAN messages and display them on LabVIEW?
Open the example finder and examine the example coming with all those CAN drivers...
(IMHO you don't need CANopen for ECU reading.)
09-21-2022 01:16 PM
@Kulani93 wrote:
Hi all.
Well to start with you need the CAN specification from the manufacturer to know how to decode the CAN messages.
But in general I used a Producer/Consumer architecture in my two can bus sniffer projects.
Here's an example...
09-22-2022 01:46 AM - edited 09-22-2022 01:59 AM
Thank you so much, this is exactly what I was looking for. Just to see the logic and the API's that are used.
My only issue is that I can't find the NI-CAN Channel API's that you used in the example. I tried searching for them on the Function Block e.g. CAN Read, but I don't get any blocks.
I believe they should have been included when I installed the NI CAN drivers? Or please tell me how I can get them.
I have the LabVIEW Base version.
Edited:
All the software currently installed.
Self test was a Pass for the USB 8473
09-22-2022 02:02 AM
I see NI CAN is for the 32 Bit version of LABVIEW and I have the 64-bit version.
Could this be the reason I can't see the blocks?
09-22-2022 02:21 AM
09-22-2022 04:05 AM
Thank you.
I have installed the 32-bit version of LabVIEW. I can now see the Industrial Communication Library. I currently have the CANopen blocks.
I see that the blocks differ from the example @RTSLVU posted.
Which library is that? Where can I find it?
Industrial Communication - CANopenn
09-22-2022 04:18 AM
Hi Kulani,
As I wrote before you usually don't need CANopen to communicate with a common ECU…
The functions in RTSLVUs image are from the (old) NI-CAN driver.
09-22-2022 06:16 AM
I now have the CAN Functions similar to the example. I just had to reinstall the NI CAN Drivers to be inclusive of LABVIEW 32 Bit.
Thank you.
NI
09-22-2022 06:20 AM
As you are using the old USB CAN dongle, you can't use the Industrial Communication Library.
You need to use the old NI-CAN library og NI-XNET with NI-CAN compatibility.
