CAN Driver Problem
I have developed an application to communicate with CAN interface.I am using PCMCIA CAN series 2 low speed card.
When i am executing the application i am getting the error like this
Error -1074388990 occurred at an unidentified location
Possible reason(s):
NI-CAN:  (Hex 0xBFF62002) An internal error occurred in the NI-CAN driver.  A description is located in the file NicanErr.txt in your ..\NI-CAN\bin folder (typically located at C:\Program Files\National Instruments\..).  Solution:  Email or fax the NicanErr.txt file to National Instruments for technical support.
I herewith attached the NicanErr.txt..
Can u tell me what might be the reason for this
Regards
Meenatchi
(4,063 Views)
I would recommend to post this question to the CAN board.
(4,051 Views)
Hi Meenatchi,
I found the following KnowledgeBase article which outlines possible solutions to your problem.
Error Code -1074388990/ 0xBFF62002 with NI-CAN
You can also search ni.com for other forum posts relating to this issue. If you still get the error, please post a reply including your code.
Thank you,
Simran K
(4,022 Views)
