CAN I USE SCXI FOR WAVEFORM OUTPUT???
HI
 I am curious can I use the channels on  SCXI 1321 to output waveform (say sine waveform)?? Or are they used only for  Strain gauge appplications?
Krithika
(2,697 Views)
Krithika,
SCXI 1321 is a terminal block which is used  to connect signals to SCXI 1121 module
So you must be asking if SCXI 1121 can be used to generate sine wave.
the answer will be: No it cannot be used for the purpose you specify since it can only give a constant current or voltage excitation output
regards
Dev
(2,683 Views)
Hey Krithika,
Oops, i did not observe that this question was posted in Labview section.
i advise that you use SCXI board of discussion forum, since this question is more relevant to that section and you will get prompt reply.
regards
Dev
(2,679 Views)
