CAN Transmit Signal only once
Dear Labview Users,
I am using the NI-XNET palette and, for test purpose, I would like to send one signal only once, avoiding continuous repetition based on information written in the .dbc files.
I tried to stop the session immediately after the write, but it seems that in this way the transmission never happens
Thank you very much for all your kind support
(2,525 Views)
Did you look at the examples that ship with LabVIEW?
Tim
GHSP
(2,514 Views)
Dear Tim,
thank you very much for your attention.
I saw the example for CAN Signal Output Single Point Start Stop Session.vi, but it seems to me that session is stopped on a user event.
On the other hand, I would like to stop the session as soon as the first transmission is completed. I saw here http://zone.ni.com/reference/en-XX/help/372841W-01/nixnet/modesignaloutputsinglepoint/ the :trigger:.<frame name> syntax to stop the transmission, but it doesn't seem to work for me...
(2,498 Views)
