CAN bus frames
Hello All,
I'm trying to send two frames on CAN bus, but constantly I get on oscilloscope only first frame.
Equipment is USB-8502 CAN bus interface.
There is no node on bus, only USB-8502 send frames to oscilloscope...
VI is in attachment, also picture from scope.
Thanks.
(3,600 Views)
Can someone help me regarding this.
I created database, that have two frames, then open session as frame out stream, and then write.
On write I also provide array of two cun clusters.
Unfortunately I always get only first frame on the bus. There is no other frame.
Can someone advise...
Also i tried with queued and single point but I got same results.
Thank you in advance.
(3,514 Views)
Accepted by topic author milan87
Hi milan,
do you get any errors in your VI? Does your scope correctly acknowledge the CAN frames so the sender (your NI8502) can proceed correctly?
(3,511 Views)
Hi Gerd,
No errors in VI.
There is no acknowledge. there is just CRC part of frame. After that just exclamation mark.
please check att.
I'm not sure that this scope tecktronix can adjust ack part.
(3,504 Views)
Hello Gerd,
I manage to get working can frames.
I connected another device that should receive can frames on the bus, nad now I have proper acknowledge.
You have right. Thanks
(3,492 Views)
