CAN data extraction from PMSM Motor controller to LabVIEW using CAN Controller.
Currently i am working on RPM data extraction of PMSM Motor. So, I have PMSM Motor with its controller. Now, i have USB-CAN-B(CAN Controller) which i have connected to PC through USB. So, Motor Controller CANH,CANL is connected to CAN2(H,L) of CAN Controller, and i switched ON 120ohm resistor also. So, i made a VI to get data, in this VI, initially CAN2 LED of CAN controller is starts blinking but labview crashes. but now now labview is not crashing but i am getting data in labview(CAN2 LED of CAN controller is blinking). i am attaching labview files, results, can protocal pdf and CAN Controller images also.
kindly help,
i am pursuing M.tech from IIT Delhi.
THank you
(659 Views)
