CAN driver installation with Labview 2023 Q1
This is my first forum post.
I would like to receive CAN messages from a CSM CAN MiniModule that is connected via Vector VN1610 USB/CAN interface.
Searching the web and forum I found the great work and documentation from TroyK and Hooovahh in regards of using Vector HW with Labview.
I downloaded the All CAN Package from Hooovahhs Blog and it states that the hooovahh_can_drivers are missing. Also downloaded CAN Drivers 1.0.1.7 and try to install it. But somehow it seems that it is not installed.
Using Labview 2023 Q1 32-bit and 2022 Q3 64-bit.
Does anyone faced same issues?
I would be happy about any feedback or help.
(2,283 Views)
Here is a link to download the latest XL Driver Library from Vector:
https://www.vector.com/int/en/download/xl-driver-library-203014/
It contains the vxlapi.dll
I haven't tested the wrapper library with that version though and I can't seem to find where to download old versions of the driver library.
Is that what you're after?
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(2,244 Views)
Thank you.
I already installed the latest version of Vector and Vector HW is detected correctly.
When I use the Vector Example CAN Read and Write.vi from Vector XL LV2018 v3 it can read the CAN messages.
However, I would like to try Hooovahhs solution as well and install the VIs via VIPM.
(2,229 Views)
