CAN frame Error -1074384895
Hi
I'm trying to write and read CAN frames using one of the CAN frame input and output-same port single point example vi and getting an error. I've attached the error message screenshot. There is a similar KB solution but I don't know exactly how to implement it. How can I fix this problem?
(3,599 Views)
Hi SolPS
Is this the KB that you are talking about?
Which version of CAN or XNET drivers are you using?
Could you attach a screenshot of you code?
Regards
Esteban R.
(3,571 Views)
