CAN real time data logger
Hi:
I am a graduate student working on a project that involves Labview.  This is my first exposure to Labview so please bear with me.
I have a cRIO 9024 with a NI 9853 CAN module.  At the moment I am trying to develop a data logger that will take CAN signals in real time and save them for later viewing.  Eventually, the data logger will be used in a hardware in the loop system, another topic I am new to.  A vehicle simulator has been developed that will act as the plant.  From my understanding, data will be sent from the simulator, converted to CAN signals and then logged.  The "ECU" will then take CAN signals sent out of the cRIO back to the model after converting them back to engineering units.
What I am having a hard time with is knowing how to properly develop the data logger.  I have gone over some tutorials on data logging and I've looked through the CAN examples on labview.  Specifically, I am wondering if the channel API vi's are what I should be using and is there a way to save to a file the signals that go to the FIFO.
Again, please excuse my low level of understanding on these things if I got something completely wrong.  Thank you.
Message 1 of 8
(4,265 Views)
You can't use any of the NI-CAN vi's with that module on a cRIO.
You will have to program the FPGA in the RIO to recieve the CAN data and transmit it to the RIO.
Try see this: FPGA CAN Engine Reference Example [broken link removed; article no longer available]
Message 2 of 8
(4,255 Views)
You should really take a look into NI VeriStand. It has integrated support for logging CAN data and is designed to be used for HIL test systems (among other things).
Jarrod S.
Message 3 of 8
(4,248 Views)
This link about VeriStand and CAN might be of interest to you.
Jarrod S.
Message 4 of 8
(4,247 Views)
I'm trying to use the example but when it starts loading VI's it gets to some that it can't find.  I don't know where they are either?  Any ideas?
Message 5 of 8
(4,231 Views)
dkfire,
I was able to get he vi's to show up but now when I try running the FPGA to compile it i get the following error.
an fpga I/O node, i/o method node, or i/o property node is connected to an i/o name control or constant that does not match the configuration of the node
It won't show me where the error is though. All I did was make a project with everything that was in the example.  Thanks for the help and quick responses.
Message 6 of 8
(4,220 Views)
Jarrod_S: Before giving that suggestion, try looking up the OP's card. That CAN module is NOT a NI-XNET compatible card.
SRamirez :
I'll try it this weekend.
Message 7 of 8
(4,206 Views)
dkfire,
I was able to finally set up a vi to log CAN data in engineering units.  I used the Frame to Channel conversion library but I've noticed that while some of the data seems fine, other parts are grossly wrong.  In other words, either the conversion from raw data to engineering units didnt work properly or the maximum and minumum was not upheld.  For example, I send in a signal for of the following bits, [2 42 51 13 15 7 51 10],
I have a scalling factor of 16 and a minimum and maximum of zero and 4000, respectively.  I end up with an array of [32, 26.4, 12.96, 3.04, -216.34375, 0, 0, 0]  Anyone else notice this issue with the conversion library vi's?
Message 8 of 8
(4,151 Views)
