CAN signals to LED
HI,
     I am sending can signals as input to  several LED to light up. If it is value 1   LED should be ON, if value is 0 LED should be OFF. I have CAN read block in block diagram which i use for  read using  signals to LED to ON or OFF. Flow goes like this
Task INit->CAN Read-> Index array -> to LED.
but from index array to LED wires is not connecting , i get a message" one terminal is double precision and other is boolean."
Is there any solution like converter from Index array to LED.
(2,446 Views)
Hi niran,
sounds like you have to insert a simple "<>0" comparison between IndexArray and your LED indicator...
(2,442 Views)
