CANopen - TPDO/RPDO object out
Hey everyone,
I'm working for the first time with CANopen and the NI 9881 module. I need to control 12 CANopen devices. For each device I'm creating a TPDO object and a RPDO object. In order to save a lot of space i want to create a Sub VI. Is it possible to somehow bundle the TPDO/RPDO out objects so i don't have 24+ output wires for the Sub VI?
SInce i'm new on the topic any help is very welcome
Best regards
Marius
(3,607 Views)
Hi Marius,
LabVIEW basics: use a cluster to bundle related data. When the datatype of those data items is the same you can even use arrays…
(I would prefer a typedefined cluster with proper labels for all elements in this case. UnbundleByName is the way to go then…)
(3,574 Views)
The problem with these objects is that you can't make fully use of clusters. For some reason -that I do not understand- if you cluster these TPDO/RPDO objects and then try to create a cluster indicator, LabVIEW refuses to do so. That also makes it impossible to create a subvi using clusters, because you need controls and indicators to attach to the connector pane.
Moreover, you can't even create a subvi where the TPDO/RPDO objects are connected to the connector pane. Obviously there must be a way, because the CANopen Addon contains a lot of subvi's with CANopen objects as inputs and outputs.
For illustration purposes, I have a screendump with part of my code, where I bundle 'interface object out' and 'RPDO object out'. That is fully accepted by LabVIEW, but when I rightclick on the 'bundle by name' cluster node and select 'create indicator', LabVIEW refuses to do so.
This forces me to use all CANopen interface objects within one vi. I do not manage to get these objects to pass the vi 'boundary'. I suspect it is my lack of knowledge for these kind of objects. Suggestions anybody?
(3,156 Views)
