CANopen nodes
Hi
Please let me know how many nodes i can connect to the CANnetwork. I am using CANopen protocol with Labview 8.2.1. And I am using more number of nodes says 70 then how the CANopen will handles the bus data.
If anybody is having some document or link then please share it.
J
(3,955 Views)
Hi J!
According to the CANOpen standard the maximum number of nodes is 127. However there is a limitation as of how that works depending on the number of messages in the network. The maximum number of messages simultaneously that the buffer can handle is 300, so if for example, you have each node transmitting 10 messages you can handle up to 10 nodes at the same time.
I hope this works, have a great day!
(3,940 Views)
Hi
So it means the number of nodes is limited by the CAN Card buffer. Is there any other method by which we can handle more number of nodes in the network....like by using software buffer ?
Regards
J
(3,919 Views)
Unfortunately the buffer cannot be extended using software, so the number of nodes that you can have is fixed by the hardware.
Rasheel
(3,896 Views)
Hi
Thanks for the reply. Can u please send the link or any document where it is mentioned....
The maximum number of CAN messages simultaneously that the buffer can handle is 300.  Please reply as soon as possible.
Regards
J
(3,889 Views)
Hi J,
That sounds right but I'm not sure where Oswald got his information from. Oswald, would you mind sharing where you got that info from?
Rasheel
(3,871 Views)
