CANopen unable to create interface
I am trying to communicate to a CAN open device using the NI PCI-8512 CAN/HS board. This vi accepts a string interface ID: "CAN2" and a Baud Rate: "50000". I run the VI and it gives me an error code: -1074388957 Source: CANopen Interface Create.vi
I've opened MAX and the CAN2 port does exist and I can open the monitor and see the heart beat messages. I am not sure how to troubleshoot this type of error at this point.
Can anybody help?
-Nate
(5,000 Views)
I'm not too familiar with the CANOpen library.  Is there a particular reason why you're not using NI-CAN or NI-XNET?  I'm pretty sure MAX relies on those drivers.
(4,995 Views)
Accepted by topic author N8D11
N8D11,
If you look at the NI CAN Product Compatibility and Feature Table, you will notice the footnote for NI-XNET compatibility with CANopen. It states that the NI-XNET Compatibility Library is required. This is because CANopen is based on the NI-CAN driver, while your device is designed to use NI-XNET. The DevZone article Migrating NI-CAN Applications to NI-XNET explains the problem in detail. You will need to rerun the NI-XNET installer and be sure to select the option for the NI-XNET Compatibility Library.
(4,957 Views)
