CASE STRUCTURES WITH TAB CONTROL
I have created  tab controlled  case structures for three different cases,
Tablet type
Machine Input
Output
It seems that data is not interlinked while switching betweeen the cases.
I have to select the start buttun for each tab to get results.And also if I skip the second tab and jump to third tab, it doesnot give results. SOmehow the data is not acquired.
Can anyone help me out for the same.
Attached is the main VI (PAR_LAB_ATT_00_01)followed by a sub VI(gen time array)
Sumit
(2,941 Views)
Please don't use all CAPS when posting your message subject.
How are you running your VI?  I don't see any while loop in it, so it only runs once.  Which means only the case structure associated with the tab that is currently highlighted before you press the run button will actually run.
The vast majority of the time, a tab control is only used to control what is displayed in the front panel and is not used to actually control the execution order of the program.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(2,936 Views)
Thank You.
(2,895 Views)
