CD Feedback controller VI for ball balancing
Hello
I need Help.
I still working on ball balancing project.
i use myrio controller with IR sensor and potentiometer and derivative the signal to get speed and angular velocity. Bcoz my system is 4th order. so it needed 4 state of input.
i can deploy this program but it is not working as i expect.
the signal of sensor give me unsteady signal.
if anyone can check it, please tell me what i should fix to make it controllable correctly.
Thank in advance
(1,308 Views)
If a signal of a sensor is unsteady, it seems like a hardware problem.
Of course filtering can be applied, but fixing the hardware is better.
(1,281 Views)
