CDAQ Change Detection
Where can I find out which CDAQ modules are capable of change detection? I can't find anything on the subject in NI website.
The 9401 seems to be capable because when I add a simulated version in a simulated 9178 chassis this module lines become available in a channel constant connected to the physical channel input of the DAQmx Timing.vi set to Change Detection.
Ben64
(3,898 Views)
Accepted by topic author ben64
Hi ben64,
The NI 9401 does support digital change detection. For a list of supported hardware, and more details about this subject, you can read about it at the link below.
Digital Change Detection in NI-DAQmx
Hope this helps!
By the way: This seems like a multifunction DAQ question, so I would recommend posting on our DAQ forums in the future.
https://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
(3,827 Views)
Thanks, I was looking for such a document that listed hardware supporting change detection but could not find any.
Ben64
(3,821 Views)
