CDB Engineering notation digit limit
Hopefully this is an easy question.    I have an output array which contains Complex DBL data points, that I'm trying to format to match a CITIfile format:
http://cp.literature.agilent.com/litweb/pdf/ads2004a/cktsim/ck0419.html
This format limits the data to no more than 11 ASCII characters in Engineering notation.
The problem that i'm having with LabVIEW is that it is inexplicably adding characters ahead of the decimal point (should just be one character), which then truncates the Exponent.   How do I limit a CDB number to 6 digits in the following format (the little "x"s):   Sx.xxxxxEsX    ?
I have attached a testing VI, which generates the Array data, then tries to format the data, and write to a ASCII file.   NOTE:   Please be aware, This VI will prompt you to create a file to write data to on your PC.   I have attached two sample files showing the correct output that i need ("correct"), and what it is currently doing ("test").   These can be opened with notepad to review before running the VI.
Any help would be appreciated.   I'm sure this is something simple that I'm overlooking.
(4,039 Views)
Accepted by topic author SparkyOne
Hi One,
why do you convert to string instead of using FormatIntoString properly?
Edit: you can even use ArrayToSpreadsheetString here…
(4,026 Views)
The easy answer is, "Because i don't know any better".
I'm learing things on the fly....which means I don't always use "proper" methods.
Thanks for the formatting lesson.  Kudos.
(4,008 Views)
