CDEx Triangle Setpoint Profile.vi
    In the example CDEx Triangle SetPoint Profile.vi in LabVIEW 2009.Can we view a step or any other signal instead of that traingular waveform??
Thanks as kudos only:)
(3,219 Views)
Hey
The VIs that have "CDEx" in front are 'example code' that we ship with the product as an example. You can open the VI, alter it and save the modified VI with your own name.
In this example, you can replace the "Triangle waveform.vi" with any VI from "Signal Processing >> Waveform Generation" palette. For obtaining the step, you can use the "Square waveform.vi" instead. If you can't find a profile, you can always use the functions in the "Programming >> Array" and "Programming >> Waveform" palette.
Hope this helps.
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,208 Views)
Accepted by topic author danil33
Thank U verymuch for your replySmiley Happy
(3,197 Views)
