CDK_item_onDoProperties.vi proxyCaller
Hi, Labview popped up the following message when I was mading an installer:
CDK_Item_OnDoProperties.vi ProxyCaller >>
CDK_Item_OnDoProperties.vi>>
AB_UI_Framewk_Installer.lvclass:Validate.vi >>
IB_MSI.lvclass:validae.vi >> IB_MSI.lvclass:Prompt_Missing_Products.vi ....
Btw, I use a back up iso file for DVD1. First, when I builded the installer, a messagse showed that some compoents need DVD1, then when I selected the virtual disk  of Daemon , with image
file loadded, it popped up the above message.
(6,012 Views)
Were you ever able to resolve this? I can still press continue but do not know yet if it will cause problems with my installer or not.
(5,879 Views)
I didn't change anything, yet it seems to have gone away. All I did was go to the additional installers page to look and what was checked and now the warning seems to be gone. Weird.
(5,876 Views)
when the troubles come back.....
then try this:
Installer Builder deletes contents of Volume\bin folder before each build
(5,857 Views)
Just to add, i have just experienced the same issue (XP, LV 2011).
Restarting LV/computer did not resolve.
Viewing the 'Additional Installers' page and unselecting & then reselecting the 'Copy selected installers to this computer before building' then attempted to build. No warning and build completed...
(5,725 Views)
It's now 2 years later and I got bit by the same thing. Lost the whole day to it. Unchecking and checking 'copy selected installers to this computer before building' also fixed it for me.
Jim Haas
(5,476 Views)
Hi All,
I am facing this same issue with my LV project. I'm using LV2011. I tried unchecking and Checking the options from the additional installers tab but it doesn't seem to be fixing my issue. I also tried restarting LV. But I'm still not able to build the installer. I have attached an image of the error. I would be glad if someone could help me with this.
Thanks and Regards,
Nitz
(5,091 Views)
