CDMA and TDMA Simulation for IEEE 802.16 using labview
Is it possible to simulate in LabView, IEEE 802.16 based wireless network with CDMA and TDMA as physical layer options for comparative study without using any devices (hardware devices)?
(6,142 Views)
While I am not aware of an instance where this has been done successfully, it might be that nobody has tried it yet. Perhaps you can check out the RF Modulation Toolkit. You might find something useful there. If you have any questions or comments, let us know and we'd love to help you out.
Cheers,
Emilie Kopp | Applications Engineer | National Instruments
(6,116 Views)
please if you can modify MIMO-OFDM OR UPLINK CDMA to MIMO-WCDMA , i want the UPLINK and DOWNLINK  simulation please give me the simulator if you have it . i want it for this friday
(6,075 Views)
I'm not familiar with what you have requested. It's highly unlikely that someone will write code for a specific application for you. But perhaps if you elaborate on what you are attempting to do, others may be inclined to offer you suggestions and help on how to do it.
Cheers,
Emilie
(6,051 Views)
please if you have a cdma.vi uplink and downlink because i want to modify it to WCDMA . at z.noufel@yahoo.fr.
I have a simulation of CDMA but in germany please give me some explication.thank you
(5,985 Views)
PLEASE !!!! can you help ??????
i want if possible small TDMA simulator code source in JAVA ( Multiplexing and Demultiplexing )
(5,942 Views)
jaures,
While I'd like to help you, I'm not familiar with coding in Java. Rather, most of the community members have gathered here to discuss applications that use LabVIEW. You may have more luck posting this request at a Java-focused forum.
Good luck!
-Emilie
(5,920 Views)
