CGI's are not processing LabVIEW InternetToolkit 8.2.1
You may also want to make sure that you are accessing your webpages under the G Web Server with a URL like:
http://localhost:81/examples/accpanel.htm
The ":81" is necessary in order to tell your web browser that it should use port 81 rather than the default port 80. I hope this helps!
Casey Weltzin
Message 11 of 14
(1,201 Views)
Phil,
I am a long time user of the internet toolkit as well. Currently I am stuck with the same problem as you are, having to share a port 80 between a web panel application and the g-web server (for user/pswd authentification). If the built in web server could handle cgi calls we would not be stuck having to do this at all.
What I have come up with is this : sharing port 80 works fine in LV7.1, it does not work in 8.2.1, acording to NI it works again in 8.5. When port 80 is enabled both as the G-web server and as the built in web server, the CGI's are not executed as cgi's, but rather treated as static files, the G web server therefore makes your browser download the CGI instead of executing it. Running the system on two ports is of course easy and works, but is a firewall nightmare that will never work in any free country 😉
Let me know if you find any solution, I think I am returning to LV 7.1.
søren h jensen
p.s. I am running a carpool database programmed in LabVIEW on the site www.pendler.dk. Originally programmed in PERL in 1996 its been operating in LabVIEW the last 7 years. I have very few crashes and the G webserver is completely imune towards any kind of remote attack. The cgi extention ".vi" is not that common 🙂
Message 12 of 14
(1,191 Views)
søren,
Since I do not at the moment really need to do any input processing in the CGI I was using and found a workaround for my needs, I have not looked closely at the HttpServer.vi. I did take a short look and it seems that it may be possible trace through HTTPServer and figure out where the problem is I'd start with isCGI and HTTP CGI Run Q Handler. It is possible a local variable is no longer being set or a default has changed.
BTW: I have installed the 6.0f2 ITK patch, the change may have been introduced then since I did not have this problem in LV 8.2.
Phil Bailey
Message 13 of 14
(1,188 Views)
Hi Phil,
With the option Share LabVIEW Web Server Port turned on (using port 81), I am able to access my CGI VIs without problems (both the G Web Server and the LabVIEW Web Server are enabled). I am using LabVIEW 8.2.1 as well, so I think that we may have slightly different settings from each other.
Are you accessing your CGI VIs using <hostname>:81 format? What happens if you try to share port 80 and then access your CGI VIs from the server machine? I am sure that we can work together to determine what is happening here.
Casey Weltzin
Message 14 of 14
(1,182 Views)
