CHARGING and discharging capacitor CIRCUIT USE LABVIEW AND DAQ
welccom excusme help me
i want build bloack diagram about charging capacitor circuit
using labview and daq 6034
charging and discharging i can not build these in labview
help me
abeer
(4,695 Views)
Hello abeer,
please explain exactly what do you want to do ? Do you want to build up a simulation ?
Which tasks (analog input, analog output, DIO) do you want to use of your 6034 ? Which version of LabVIEW and daqmx drivers do you dispose i.e. 7.1 ? On what input or output voltage and current area do you think of ("0-10 V" alternatively "0-xx mA") to charge your capacitor ?
Please describe in-depth your capacitor circuit !
Regards
Kristian
(4,664 Views)
help me
abeer
thank you for reply
i build charging capacitor using daq 6043 and labview version 7.1
we use analog input
to read signal from ciurcuit build out of computer
i want example by build in block diagram
and our problem apear when we determine the time to paint the charging graph
i want help me
in short time
another problem we want measure ac voltage use analog input
but the rms is not measure correct
itwas measured change
abeer
(4,652 Views)
The easiest way to determine the capacity of a capacitor is the step response. The measurement basic´s you will find here. To aquire voltage with your 6034 use for example the DAQ Assistant -> input configuration "voltage" or refer to the examples which shipped which LabVIEW (Help-> Find Example -> Hardware Input & Output -> analog measurement -> voltage).
The timing information is delivered from your daq-assistent and is dependent from sample rate.
_______________________________________________________________________________________________
"another problem we want measure ac voltage use analog input
itwas measured change"
-> Proposal: Aquire analog voltage -> Analyze received 1D-Array with complete subvi´s shipped with labview (you will find a vi called RMS.vi or mean.vi in the analyzed function palette -> or search in blockdiagram for RMS).
(4,636 Views)
