CI Pulse Width
I am trying to use the CI Pulse Width to measure the pulse width of a signal.  I am using a digital output to trigger a 555 monostable timer which sends a signal to a Parallax Ping, which in turn sends out a signal.  I am trying to use the counter on a NI USB 6008 DAQ to measure the pulse width of the signal coming back to the ping after reflecting off of an object, but I keep getting the error:
Possible reason(s):
Measurements: Selected physical channel does not support the measurement type required by the virtual channel you are creating.
Create a channel of a measurement type that is supported by the physical channel, or select a physical channel that supports the measurement type.
Property: CI.MeasType
You Have Requested: Pulse Width
You Can Select: Count Edges
Task Name: _unnamedTask<E6>
Is it possible for me to use the CI Pulse Width to measure the width of a external signal?
(5,635 Views)
I thought this was possible also, but it is not. Not with the USB-6008. The 6008 only counts pulses and then it only counts them on the falling edge.
I think for your application you could use the express VI "timing and transition measurments"  and bring the pulse in on an Analog in port. The Analog in on the USB-6008 can sample at 10kS/s . I am attaching 2 VI's that use the 6008 as the Daq and count pulse width.
I am sure the experts can inprove on these but both are working here on my bench.
Alan
(5,622 Views)
I would truly be interested in any constructive criticism of the VI's I attached to this thread. Both are working for my application of measuring a pulse width in MS. The duration is the width. I am confirming the freq and pulse width measurements  against a Tektronix TDS 1002 scope sampling at 1GS/s attached to the AI0 port the pulse is coming in on and the results are very close. I was going to try Hardware triggering later on today, not sure if that would help?
Thanks!
Alan
(5,619 Views)
Would you be able to upload these in 8.6 instead of 8.6.1?
(5,603 Views)
Ok,
The second VI I changed anyway and now it has a trigger, at first glance it seems to make the measurement more accurate, but Im not sure yet. (didn't make it any worse) I also cleaned up the BD on the second VI.
Alan
(5,596 Views)
