CIN access to DLL 2
I'm trying to write a few routines to interface with a Bosch SCARA robot using a DLL provided by Bosch. The DLL assumes that applications will be written in C and is not complete, requiring extensive use of "includes" which cannot be readily accommodated in LV.
I have begun dabbling in writing CINs to run snippets of code which will pass the required
parameters to the DLL and read the output. To date I haven't had much luck, and I haven't been able to find much assistance in solving this problem.
The code below is the first function that I am trying to set up. It sets up a TCP/IP connection with the robot's controller so that other hardware specific functions can be called.
After having debugged the C code, I am now of the opinion that I must be doing something wrong with the variable types so that LV is becomming confused. The lsb file generated from this code runs, but doesn't output a ChannelId number.
Can anybody offer any assistance, please. I may consider sub-contracting this work if anyone is interested, as I am running out of time on this project.
* CIN source file
#include "extcode.h"
#include "hosttype.h"
#include "windows.h"
#include "rimp.h"
#include "rmain.h"
#include "rt.h"
CIN MgErr CINRun(LStrHandle HostName, uInt16 *PortNo, int32 *Timeout, int32 *ChannelId);
TTClientCon PTClientCon;
memset (&PTClientCon,'\0',sizeof PTClientCon);
memcpy (PTClientCon.HostName, HostName, sizeof HostName);
PTClientCon.PortNo = *PortNo;
PTClientCon.Timeout = *Timeout;
PTClientCon.ChannelId = *ChannelId;
rTClientCon(&PTClientCon);
return noErr;
This bit shows the syntax and variable types that are used by the DLL function.
/* rho-function : 11000 */
/* Function-name: rTClientCon() */
/* Purpose : Establish a TCP/IP connection to rho4. */
/* Before using any rho4-library-function, you must */
/* build a connection to your prefered server. */
/* Calling this function will establish your connection */
/* and you will get an ident number (ChannelId). */
/* You must copy this ChannelId to any function */
/* structure you will use, so don�t lose it. */
/* At the end of your work, after calling a lot of */
/* different functions, you have to close the channel. */
/* For closing (disconnecting) the channel you also need */
/* the channel ident number. See function rTClientDis */
/* For a decription of TCP/IP, the "hosts" file and the */
/* available rho4 server see documentation "GateWay". */
/* Input-parameter: */
/* - HostName : The ASCII name for your rho4. This must be the same */
/* name as in the "hosts" file from your [WINDOWS] */
/* directory. Normally it is "rho4". */
/* - PortNo : The number of the desired port. */
/* The previous installed port numbers for the */
/* rho4-library-functions are: */
/* - rho_Funktionen_1 : 6091 */
/* - rho_Funktionen_2 : 6092 */
/* - rho_Funktionen_3 : 6093 */
/* - rho_Funktionen_4 : 6094 */
/* - Timeout : The timeout in seconds. The time the function will */
/* wait of the rho4-Server to establish a connection. */
/* This effects also the functions rTWrite, rTRead. */
/* Use: - -1 for blocking mode (timeout = infinite) */
/* - 0 no timeout */
/* - 5 a fair value */
/* - any positive number */
/* See also function rTSTimeOut */
/* Output-parameter: */
/* - ChannelId : The number of the required TCP/IP-Connection. */
/* This number will be need for all following function */
/* calls. */
/* Return-codes : */
/* == 0 : the function ended normal. */
/* -5000 to -5999 : see decription above */
/* > 10000 : see rmain.h */
#define CTClientCon 11000
typedef struct TTClientCon
char HostName[30];
unsigned short PortNo;
long Timeout;
long ChannelId;
} TTClientCon;
EXTERN long STDCALL rTClientCon( TTClientCon * PTClientCon);
(2,674 Views)
instead of trying to write a CIN, I would suggest writing a DLL instead that would "package" the DLL you are trying to call in a more complete way. This way you stay with conventional tools and debugging techniques until you are ready to interface to LabVIEW. Write the new DLL functions and a simple C or VB test application till it works to your satisfaction, then call the new DLL from LabVIEW. Be carefull that the original DLL is in the Windows search path so when the new DLL goes to load it, it will find it.
If you are still looking to hire it out, look for one of the system integrators in your area with the skill set required to work with.
Stu
(2,674 Views)
