I have a VI that uses a CIN node to access a digital camera, recieve viewfinder data and return the data. This data is in turn displayed in a picture control, creating a real-time display on the front panel that shows what the camera is seeing. The whole process worked flawlessly in 6.0.2, the frame rate was fine. I recently upgraded to 7.0 and now the same VI runs a lot slower and the frame-rate has significantly slowed down (a drastic drop to about one frame per 5-10 seconds). I have watched the execution of the problem and have narrowed the problem down to the CIN node. I am wondering if anyone else has a solution/is experiencing the same problem. Any help will be greatly appreciated and the giver of such - worshipped
for generations to come.
