CIN
Hi, I'm new to use CIN. I have two questions.
1. Is it going to work if I don't have Visual C++ installed in my computer and I just do all work related to C++ in another computer and copy the file that CIN needs to my computer?
2. Is it going to work that the file that CIN needs is generated in Visual C++ .net and my compter system is Window 95. (Window 95 doesn't support Visual C++ .net)
Thanks for help.
Rena
(2,986 Views)
Rena,
The only change that you need to make in creating a CIN in VC++.NET is to add the "\lvsbmain.def" path to the Linker>>Input>>Module Definition File field. You should have no issues creating the .lsb file that you will need to add to your VI. However, your question of if it will run is not known to me. If Windows 95 does not support the .NET run-time, then it might not work. It may be something that you have to test and see.
Randy Hoskin
http://www.ni.com/ask
(2,986 Views)
