CINLoad error when executing SQL
I have an application that was written by someone else in LabView 5.1. I am bringing this upto LabView 6.1. When I run the application, it tries to Write to Database (MS Access 97). In this VI, when it tries to run the Execute SQL vi, I get the error -100 CINLoad - DLL Setup Error. I have installed the SQL toolset, the DataBase toolset, but to no avail. This is running on Windows NT 4.0.
(3,411 Views)
This error is generated when there is a missing driver. You have said that you have installed both the SQL toolset and the DataBase toolset so I assume it is not those. The Database Toolset (replacement for the SQL Toolset) no longer relies on the INTERSOLV drivers. I wonder if the missing driver might be relating to the intersolv driver that was used with the SQL Toolset.
(3,411 Views)
It turns out that after further reading, there are new SQL VIs that replace the ones used in LabView 5.1. I replaced the appropriate VIs with the new _SQL VIs, and it is now working.
Thanks for the help!
(3,411 Views)
