CLA VI properties not documented
I got the result for my CLA.  I didn't pass, but hopefull I will learn from it and do better next time.  One comment that I got was "VI properties not documented".  I put a requirement tag inside all VI properites at least.  Is that not enough?  I looked at the ATM CLA sample test, and I saw that many VI only has a requirement tag in their VI proerties, so I thought it is adequate.  What is the offical say on that?
Kudos and Accepted as Solution are welcome!
(2,727 Views)
You should have posted on the certification board...
Rodéric L
Certified LabVIEW Architect
(2,689 Views)
I reposted it, thanks!
(2,632 Views)
