CLAD Exam
I go make a CLAD exam
Someone has a sample exam with solutions ?
Thank you very mutch
raulcordeiro@plutonis.com
Message 1 of 23
(8,110 Views)
No chance you'll get the requested information since all the applicants sign a non-disclosure agreement ! Have you seen that you can prepare yourself with an on-line test ?
Chilly Charly    (aka CC)
Message 2 of 23
(8,092 Views)
Hi
I also looked for some examples, but I didn't found anythink. As chilly charly wrote, you could do LabVIEW Fundamentals Exam which is similar with CLAD (that people from NI said). There is also some examples CLAD exam, unfortunatelly without answers: http://www.ni.com/pdf/custed/us/sample_clad_exam.pdf
Yesterday I pass CLAD exam so don't worry. If you pass LabVIEW Fundamentals Exam without any problem you should also have no problem with CLAD,
bogdani
Message 3 of 23
(8,088 Views)
Take a few online testsSmiley Wink
that's a preperation good enough!Smiley Very Happy
all the best!
Message 4 of 23
(8,068 Views)
Thank you, but in this simple exame CLAD the people from NI in my country don't know the answer to question 8 (code snippets). I think it's b) option, but they think probably it's a) option.
Everibody agree with me (b option)?
I put this sample exam in www.plutonis.com/clad.pdf
THank you
Message 5 of 23
(8,063 Views)
I bogdany
I have same examples of the online tests i already fone, if you want i can email to you.
All the best
raulcord
Message 6 of 23
(8,058 Views)
THank you
No luck, it's option A.
Option B is at least 100 times slower. Avoid using property nodes : They force LV execution in the User Interface thread, among others inconvenients shared with locals/globals. The only exception is when you have another operation to do on a control properties. Since you are already stuck there, you can take the opportunity to use the property node for a value access.
Message 7 of 23
(8,045 Views)
I couldn fine the sample exam in the website given by you. Can u help me out in this regard???
Message 8 of 23
(7,345 Views)
  Can you tell me where can I find the sample.pdf in www.plutonis.com/clad.pdf???
Message 9 of 23
(7,343 Views)
Hi Devi,
you're asking in a two-year old thread for a file located on an upload-service website... I don't think you will get the file there...
Have you checked NI's website for information on CLAD exams?
Message 10 of 23
(7,318 Views)
