CLAD Questions
Nor their order is based on their position in the shell.
- Partha ( CLD until Oct 2027 🙂 )
Message 11 of 16
(2,289 Views)
The default pattern has 12 terminals. You do know how to change the terminal pattern right?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 16
(2,270 Views)
GovBob wrote:
If you have LabVIEW why don't you try to find the answers? For this question just open a blank vi and place a cluster box on the front panel. Add a string control, a numeric control and a boolean control into the cluster box. Right click the border of the cluster and choose reorder controls in cluster. Smiley Wink
Why is simple. The guy who started this thread doesn't really care about knowing or understanding LV, he just wants it to look like he knows LV by getting a piece of paper. Look at the questions he's asking. For most of them, if he doesn't know the answers or know where to find the answer without asking for help, he doesn't deserve a certification.
Mike...
LabVIEW Champion
Message 13 of 16
(2,266 Views)
Are you sure about that?
cluster
Message Edited by vt92 on 03-06-2009 07:46 AM
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 14 of 16
(2,247 Views)
cluster
That agrees with Parthabe's statement.  It was a continuation of his previous message as to why B was not true,  NOR why C is true.  The order is NOT based on position in the shell.
Message 15 of 16
(2,232 Views)
However, if you configure the cluster with "AutoSizing...arrange vertically (or horizontally)", their position in the shell is always sorted based on the cluster order.
Under these condition, you can tell the order uniquely from the position in the cluster container.
Of course the statement "their position in the shell is based on their order" is not quite the same as "their order is based on their position in the shell". 😄
Message 16 of 16
(2,190 Views)
