CLAD sample exam - windows dialog button mimic
While preparing for the CLAD exam, I don't seem to agree with the given answer:
What mechanical action of a Boolean would you use to mimic a button on a Windows dialog?
The given answer is "Switch When Released".
Maybe it depends on which button, but when I think about a typical Cancel or OK button, the action happens after releasing, so I would think it is "Latch When Released".
Am I alone in this opinion?
Stijn
Message 1 of 17
(10,161 Views)
I think I'd agree with you there.
The when released part in both answers is accurate.  That is the behavior that it doesn't take effect until you let go.  If you've ever noticed, you can press, hold, drag the mouse off the button then let go, it is like the click never happened.
The difference between latch and switch is that latch causes the button to automatically pop back to its original state once it is read in the program.  Switch does not change back.  All windows dialogs I've seen appear to pop back once you are done pressing them.
Message 2 of 17
(10,159 Views)
I agree with both of you, the correct behavior is Latch When Released.
Where are you seeing this practice exam?
Brian Spears
Sixclear
Message 3 of 17
(10,148 Views)
where I've found the exam?
http://www.ni.com/pdf/custed/us/sample_clad_exam.pdf
question 17
Stijn
Message 4 of 17
(10,124 Views)
It's kind of a trciky question and it depends on the programmer.  I think I understand why it could be argued to be switched when released.
Typically, when you press a button on a dialog box, the button stays pressed until the appropriate action completes.  For example, if you hit an Apply button, the dialog box completes all actions associated with the Apply button, then resets the button to the off state.
Depending on how you write your program, you can have the same behavior accomplished with a latch button as well.  You just have to read the control until after you have finished your actions.  In some cases, it may be quite simple, but in others, it may be more difficult if you go through several states before the action is complete.  But, it is possible to get the same behavior out of both.
I think a lot of us have been programmed that locals are bad, so manually resetting the switch is bad.  It doesn't help that NI also has the buttons on the control pallette setup to latch when released either.  You would think that if switched when released is the correct answer, that NI would have their OK and Cancle buttons behave in that manner.
Message 5 of 17
(10,106 Views)
I would have to agreen with you and the behavior of most Window buttons.  I got this question "right" on my CLAD exam, but only because I new the answer from the practice exam, not that I agree with it.  Perhaps some of the NI App Engineers can chime in with a better explanation as to why this is so.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 6 of 17
(10,102 Views)
Edit:  I'm not sure what happened.  My post got posted twice.Smiley Surprised  Sorry, I don't know if there is a way to delete posts or not.
Message 7 of 17
(10,101 Views)
That question is even trickier for someone who does not use Windows!
This has been pointed out to the people who develop the exams, so they are aware of the problems associated with that question.
Lynn
Message 8 of 17
(10,065 Views)
CLAD Sample Exam-2b.pdf file: question 31
sample_clad_exam.pdf: question: 17
What's the right answer?
Message 9 of 17
(6,402 Views)
You do realize the PDFs you posted have the solutions at the end?
Message 10 of 17
(6,394 Views)
