CLAD test taking question
Some simple questions to get mentally prepared for the CLAD test.
Are you allowed to skip questions and go back to them later?
If this is allowed do you think it is a good strategy  to answere all the easy ones first?
Are you allowed to bring in paper and pencil?
Am I correct it is 40 Questions in one hour?
Thanks!
Alan
(4,935 Views)
Yes you can flag questions and go back to them
when I took it on Monday I went through all the questions twice
they give you a erasable piece of paper and a marker so you don't have to bring your own
yes 40 questions 1 hour
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,929 Views)
Thanks for the quick responce, one more question.
Did you find the test very similar to the NI fundamental on line test? Easier, harder the same?
Alan
(4,922 Views)
About the same as CLAD prep tests. IMO, a little easier than the Fundamentals test.
The test could be on computer or on paper. Either way, you'll get some paper and a pencil to figure out those loops Smiley Wink.
Be careful of the questions where more than one answer may apply - the test will tell you when this is the case.
You'll likely finish early. Use that time to recheck your answers! You don't want to get a question wrong just because you ticked the wrong box.
Message Edited by Broken Arrow on 10-22-2009 10:33 AM
Richard
(4,918 Views)
Accepted by topic author ajmartin
they where a bit different, but it is the same setup and same type of questions
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(4,917 Views)
Yes - for both the printed and the computer-based version
That's up to you!!
IIRC paper is provided; you can bring a pencil!
Yes.
Thanks!
Alan
Have a look at the sample exam at
http://www.ni.com/pdf/custed/us/sample_clad_exam.pdf
Rod.
(4,909 Views)
