CLAD
Hi
I go make a CLAD exam, i already done some online sample tests, but i have questions where i don't know the correct answer like the local NI dealer in my city, so i ask help to you...
I have 5 questions that i like to know the correct answer, they are in http://www.astrolusis.com/clad_questions.pdf
Thank you
All the best
raulcord
(4,868 Views)
To Q 31, the answer as I can see it is 3).
Gain can also be fractional, i.e. x0.1
Reading a signal smack in the middle of your dynamic range is basically the optimal situation.
1V should be with a gain of x5,
10V with a gain of x0.5
and the 10V with a range of 5V should have a gain of x0.25
It assumes that the gain is performed in analogue mode.....
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(4,865 Views)
And, I don't agree with your choices for questions 1 and 27.
(4,841 Views)
I'm with Dennis on this one.
Revisit questions 1 & 27.
Others look fine.
Message Edited by JoeLabView on 05-30-2006 10:35 AM
(4,834 Views)
Hi Dennis
Yep, but this is the answer that the NI office in my country give me is this one !
What you think is the correct answer ?
For 1- A  and for 27 - D ?
Thank you
raulcord
(4,808 Views)
Hi Shoneill
Thank you
raulcord
(4,805 Views)
I could give you the correct answers but how would that help? The answers are pretty easy to come by and maybe you should do a little more research and studying before taking the test. If you think A and D are correct, you should be able to explain why.
(4,800 Views)
