CLD-R Exam 1, Question 22
I am sitting the LabVIEW CLD-R exam in a few days & attempting some of the sample questions.
Question 22 has me stumped, I just don't get it.
I tried it in LV 2015, and can't seem to get the correct answer.
Can anyone explain to me whats happening here, (I generally don't use recursion, which is why I don't get it I suppose).
I will attach my attempt (that does not work..)
Thanks in advance for anyone's help
Message 1 of 12
(6,957 Views)
Just to help... attached is the actual question, just in case people don't have the exam papers.
And apparently, this is is the correct answer, (the VI attached)
Kevin
Message 2 of 12
(6,910 Views)
Accepted by topic author kevin57
Your VI-upload contains one error in comparison to the sample exam. You missed to connect the string "ExprOut". Add this to your VI:
There's also a second smaller problem with the suggested solutions from that sample exam: it is written for an environment with a dot as the decimal point. So it you use a comma as the decimal point, that's why I added explicitly the false constant to the conversion to string.
Regards, Jens
Kudos are welcome...
Message 3 of 12
(6,902 Views)
Very good... thank you very much.
I cannot believe I missed that... no excuse I know, but it was late at night I was trying these (so obvious now that I see it...).
Now that I see it working I get it, thanks heaps.
Kevin
Message 4 of 12
(6,872 Views)
Hi you guys.
Still I can´t get why answer D is the right one. Probably something related to recursive function? I was learning about this but still can´t get the reason why D is right.
Can anyone help me?
Message 5 of 12
(6,458 Views)
Recursion is a bit of a pain to understand. but you Have to have a way to STOP recusing or, you are gonna curse forever. So, example D chooses if it is appropriate to call itself again where C does not.
Message 6 of 12
(6,449 Views)
Thanks Jeff, but, opción B also stops recursing the VI. so whats is different there?
Message 7 of 12
(6,446 Views)
The only real difference I am seeing is the Result double being stored in a shift register.  I would need to spend a lot more time going through the code to figure out if it really should be there or not (my current thought is NO).
Message 8 of 12
(6,438 Views)
You are thinking correct.  The result of the incurred step is the output of the case.  so the loop output is not what you want as the result.
Message 9 of 12
(6,432 Views)
Thanks !!!
Message 10 of 12
(6,407 Views)
