CLD exam
My Instructor for the LabVIEW Intermediate class took the Re-certification exam and told me that it is similar to the CLAD.
Message 11 of 24
(2,008 Views)
I recertified my CLD, and yes it was a one hour Q and A.
The first time I certified for my CLD, it was a 3 hour coding and a 1 hour Q and A exam.  I guess that has changed now.
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
Message 12 of 24
(2,008 Views)
Now it is 6 hours of coding cut down to 4 hours time, no Q&A.  I wish they would cut down on the coding.  4 hours is too long to sit in one place.
- tbob
Inventor of the WORM Global
Message 13 of 24
(2,003 Views)
The recert is Q&A, not trivial. I find that I have a hard time with some questions in that environment as I never think about them in the LabVIEW environment, i.e. I don't always "remember" whether a value brought out of a For loop is automatically set to "auto-index" , because when I am wiring it obviously is. Then if I don't want an array there, "click", so knowing that doesn't improve my LV "experience".  As to the 4 hours being too long a time, well you don't need to use it all  Smiley Wink    It is a long time, although about 1/2 through it seems like the clock speeds up. Yes, the bi-annual renewal seems a bit much (as I realize that the first year has almost passed since my re-cert), particularly when taking the recert for some of us is a day off from work, which in the consulting world is a day off from billable hours. So the $195 US or so becomes considerably more. Add to it that the exam, at last check, isn't given within 100 miles of where I live and it becomes more than a little annoyance.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 14 of 24
(1,978 Views)
tbob wrote
" I think every 5 years would be plenty. "
I agree strongly*!
Ben
PS: Having completed my re-cert for CLA last Friday and assuming that I sqeeked by), that means I will only have one more test between me and retirement.
Message 15 of 24
(1,969 Views)
They don't give you instant feedback with the CLA?  When I recerted for the CLD I was told that I had passed immediately, made the 2 1/2 drive home much better than the 2 1/2 drive there. Of course, picking up one of our kids from college also made the trip worthwhile.
Putnam
LabVIEW Champion
Message 16 of 24
(1,937 Views)
"They don't give you instant feedback with the CLA?"
How could they grade a four hour essay test instantly? I think it took a month and a half to hear back the the first time. So I figure I'll find out about February.
You aren't confusing the CLAD with the CLA exam are you?
Ben
Message Edited by Ben on 12-19-2007 03:00 PM
Message 17 of 24
(1,932 Views)
No, just wasn't familiar with the CLA exam. Now there is a case where 2 year renewal seems really silly, the primary  concepts of architecting a large LabVIEW project will change a lot in the next 2 years, major paradigm shift that will invalidate the major concepts you have worked with for the last two years!  I might believe that to claim to be a knowledgeable "developer" you might be expected to demonstrate familiarity with the more current versions, although I'm not sure what in the CLD recert would do that, but while you have undoubtedly learned some kewl new stuff in the last 5 years, would what you knew when you originally passed the CLA be so out of date as to make passing it now in doubt?
Putnam
LabVIEW Champion
Message 18 of 24
(1,911 Views)
Putnam wrote "would what you knew when you originally passed the CLA be so out of date as to make passing it now in doubt?"
The public domain info that NI reveals about the test shows that new concepts will be evaluated. I'm not revealing anything by saying that.
Lacking the test requirements, I could have done the design about the same way. ("There is nothing new under the sun." Eclesiastis ?)
Ben
Message 19 of 24
(1,906 Views)
The CLD doesn't give any instant feedback.  When I took it a couple of years ago, it was 4 hours of programming.  It took a month or so to hear back.  If the CLAD was ever together with the CLD, you would have gotten instant feedback on it, as it is just multiple choice and graded by the PC.  Currently, the CLAD and CLD are aeperate exams, and you must pass the CLAD before you can register to take the CLD.
Message 20 of 24
(1,899 Views)
