CLIN can't find functions in a built DLL library
I'm trying to use a DLL library that I built using MS Visual Studio.NET, which contains just two functions. When I use "configure" to place the DLL in the Call Library Function Node (CLFN), it says that the functions were not found in the library. I went to the NI support site and found the utility VI that checks for the functions actually exported from a .dll file and, sure enough, the two functions appear in the list with no error, yet the VI will not function and gives the same error. Can anyone help with this?
** UPDATE **
Figured it out. I didn't see the pull down menu in the configure dialog box where you must specify the function name to be used from the library.
All is well...
Message Edited by BioDave on 06-13-2005 12:02 PM
(2,598 Views)
Hi BioDave,
I appreciate that you took the time to update your post when you found the solution. That saved me some time, that I now can use to help others...
Thanks!
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,583 Views)
