COM PORT appearance
Hello all,
             My VISA is reading COM1 as Com1. For testing only I connected one string control directly to VISA indicator and passed the value Com1(by mistake). Since then in the dropdown list it is showing COM1 but if I select it then it is showing Com1.
Suddenly what happened I dont know. I have attached one image for better description.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 1 of 14
(4,978 Views)
And it is happening only for COM1 only
--Ranjeet
Message 2 of 14
(4,964 Views)
Perhaps your visaconf.ini changed?
Bill
CLD
(Mid-Level minion.)
Message 3 of 14
(4,931 Views)
Check the VISA Alias
MAX Menu Tools>>NI VISA>>VISA Options  will open a rather useful tool in MAX
General>>Aliases in the tool will allow you to inspect, Clear rename or delete Aliases
Message 4 of 14
(4,927 Views)
Maybe refresh your driver , In case of any DAQ try to calibrate it and then do it
Boldness has genius, power and magic in it!'
Message 5 of 14
(4,913 Views)
Does it make any difference ?    Just asking.....
Doug
"My only wish is that I am capable of learning each and every day until my last breath."
Message 6 of 14
(4,899 Views)
No it doesn't. But then also I should know why it this. Its a learning for me.
--Ranjeet
Message 7 of 14
(4,872 Views)
I tried but no difference
--Ranjeet
Message 8 of 14
(4,871 Views)
How to reveret it back ?
--Ranjeet
Message 9 of 14
(4,870 Views)
Let me check with this, Is there any other option to change it? What I mean to say is it happend through software i.e. in the VI only. Can I revert it back to normal with COM1 through VI only ?
--Ranjeet
Message 10 of 14
(4,867 Views)
