COM port doesn't recognized in Measurement and Automation
Hi , im using labview 2014 , and i'd like to initialize an srial communication , i built an vi , using VISA , but i cant choose my com port .
I dont have an COM port on my pc , im using USB to COM converter , it works great with arduino and HyperTerminal . I tried to check the Measurement and Automation , and i found that my COM port is not recognized there.
What should i do ?
thank you in advance .
(3,536 Views)
Hi Cobmetal
If you are using Arduino before you may leave your serial port busy, so LabVIEW does not recognize . Try resetting your port.
(3,505 Views)
What chipset is in the converter?
I've seen this type of problem with si labs needing to be installed multiple times because of enumeration conflicts.
(3,493 Views)
And what version of NI-VISA is installed?
(3,481 Views)
And,  Now that I think of it,  Do you have the power mananger option turned off so Windows does not shut off the USB Port?
(3,465 Views)
Thank you guys , i've just found out , the NI-VISA wasn't installed ,
install it fixed the problem.
Thank you again.
(3,446 Views)
